Service Mode
  • ODC Receptionist
    Service Mode
    How do I go into 'service mode' for a Sharp AR-337? I have been told that by doing this I can learn what the key operator code is - the copier we have is a donated one and no one knows what that code is - and we need to find this out to make it work.
    Any info or help or suggestions would be very appreciated!!!
  • Nachoman4life
    • Oct 2007
    • 212
    key op default
    the key op default code is 00000
    Where the heck is my spring hook?
    • ODC Receptionist
      thank you - i found that in one of the manuals - but that has yet to help - all i am trying to do is to change the operator code - but since we dont know what it is i can not do that - so i was trying to get into the service mode in hopes of retrieving it - any suggestions?
      • Dustin(WOP)
        • 223
        enter sim (service mode) p-interupt-c-interupt. 22 start...7 start... this will display the key operator code then in setting you can disable account codes so you never have to use this code again.
        • efe311
          • 114
          Ca-#-interrupt-ca
          sim 89-1
          will reset the key code to the defult 00000
