Check your corona main charge corona wire if it is not broken. Replace if it is. To check your developer MG roller if it will turn when you run the machine, pull out the developer unit and put a little smudge on the MG developer with your finger and slide the Developer unit back to the machine and start the machine just for a few seconds and shut it off. Slide out the developer unit assembly and check the developer on the MG roller. It it looks smooth and no more smudges then your developer is turning properly.
