Sharp SF-2314 shooting blanks
  • joni618
    I am working on a Sharp SF-2314 copier for a local Dr. who is T\'d-off at the local Sharp dealer. Seems they did a PM on it and it started giving blank copies immediately. He asked me to check it for him. When he brought it in. it was making totally blank (white) copies. I cleaned it which it needed and replace the developer. The charger looks o.k. Now I\'m stumped! Can anyone give me some sugestions? Thanks for any help you might have.
  • raym
    • Apr 2005
    • 62
    Re:Sharp SF-2314 shooting blanks
    did you check the transfer corona? run a copy and try to stop midway under drum and try to look at your image on drum. if you see it, then charge and developer are working ok and you are most likely looking at a shorted transfer corona.
    good luck,
    ray
    • joni
      I checked the drum after running a copy halfway thru and there is no image on the drum.
      • raym
        • Apr 2005
        • 62
        hi joni, i\'m not the most proficient on sharps but going by the theory of operation, i would say check your charge corona very carefully, make sure your developer roller is turning, and check your high voltage transformer in that order. i hope this helps some.
        good luck,
        ray
        • joni
          How do I test that the developer roller is turning? I understand that on this unit it sometimes turns by hand but not when installed into the copier! Thanks for your help, Ray
          • raym
            • Apr 2005
            • 62
            hey joni, i meant by hand as that is the only way i know of on that particular unit. i hope that you have success.
            ray
            p.s. check that your brush on mag. roller is sufficient height and that its orientated towards drum.
            Post edited by: raym, at: 2005/05/24 13:03
            • Wild Bill
              • Jul 2005
              • 774
              I would suspect the developer unit on this machine. Is developer up against the drum, correctly?
              Izzy
              • R. Hunt
                • 23
                Clean the scanner rails, make sure they are lubed
                  • 23008
                  I realize we don't get to choose what we work on most of the time, but this machine isn't much. Wasn't ever much. Whomever sold the PM parts would have been much better off putting that money towards a real copier.
                  I happen to agree that it is probably some sort of developing issue. But it's still not worth fixing. =^..^=
                  • mtech
                    • Mar 2007
                    • 307
                    Must be main charge or developer.
                    • nightshade
                      Chromographic Supremesist
                      • 158
                      I agree any of the 2000 series is old and decrepit.
                      With that aside. To check to see if the DV magnetic roller is turning. Pull out the drum unit, wipe your finget on the mag roller to brush off a strip of developer, put it back together and make a copy, remove the drum again and see if the roller has turned.
                      Also to check to see if you have charge, turn room lighting off and go into crop 8 and run the main charge with the front door cheated. You should see a purplish/blue glow if it is on. Also if you see any "lightning strikes" to the drum, the charge unit is dirty or defective and the arching will cause issues.
                      Anotherthing to try to rule out the optics path is to make a copy with the top cover open "skyshot", with this you should get a solid black copy. This works good too when you stop it in mid copy to check for image on the drum.
                      • aikon_ngage
                        hey joni
                        try to check the xfer corona unit and contact, also dont forget the charge unit w/ grid ,the hvt unit and connectors. also the dv unit if it is rotating or properly set in place. changing developer doesnt help without checking this stuff first.
                        • deep
                          • Jun 2008
                          • 208
                          A post 3 years ago, joni will not back.
                          Kenny
                          • nightshade
                            • 158
                            WOW didn't notice. Someone musta been very bored to dig that far back....
                              • 23008
                              Oops! If had been paying any attention to the date, I'd have let that one pass......
