EE-EL on ARM351
  • glewisme
    • Nov 2009
    • 240
    Hey
    You failed to mention wether or not the front door was open before entering the simulations,if it was open it will immediately start a toner add which messes with your toner to developer ratios. If the door was closed you may have a bad batch of DV or a bad TD sensor ,also note the condition of the transfer roller (gear too ) and contacts.
    • glewisme
      • Nov 2009
      • 240
      oops wasn't
      I meant if the front door wasn't open it adds toner. OOOOPPPPPPSSSSSSSSSSSS!!
