Can a Sharp AR336 toner cartridge be used in a Sharp AR335 copier? Any help appreciated, thank you.
Sharp AR336 Toner Cartridge
The actual toner is the same, but the cartridge latch won't fit properly. These models use the same upper hopper (cartridge latch):
AR-280, AR-285, AR-335
AR-250, AR-281, AR-286, AR-287, AR-336, AR-337, AR-405, AR-407
AR-501, AR-505, AR-507
Did I explain that clearly? =^..^=If you'd like a serious answer to your request:
