Dead AR-M 550
  • vincent64
    • 382
    Dead AR-M 550
    Have this AR-M 550 that when I power it on, first inside switch, you can hear some relays on the PWB click on, then the side switch, a couple of fans run, and thats pretty much it.
    Had this happen last week, after checking AC and DC pwb's, I reseated the main and boot roms, and the machine powered up, ran rest of that afternoon and next day and all weekend, Mon. it went dead again.
    Tried swapping out MFP board, HDD unit, swapping EPROMS also, did no good at all, fans run, some relays cycle, but no power up.
    Thinking of the power supplys next, any ideas???
  • Dark Helmet
    • May 2009
    • 861
    I had a brand new MXM550 which is basically the same machine do the same thing. You could flip the power switches and some fans would come on and hear a few clicks and that was it. We ended up changing the DC power supply.
      • 23010
      Load 7 3/4 x 10 1/2 Paper
      I had one like this. The original symptoms were "Load 7 3/4 x 10 1/2 Paper." By the time I arrived it was dead. Fortunately for me I had a donor machine available. I replaced the power supply, then the EEPROMs, then the MFP (and it woke up). Then restored the original PS and EEPROMs (still awake and kickin').
      The thing that surprised me was that there were no outputs from the power supply, even when the outputs were unplugged, yet the board was good.
      Last edited by blackcat4866; 07-01-2009, 01:22 AM. Reason: remembered more details!
      • jprecht
        • Dec 2008
        • 104
        dead 550
        have had a # of these come through the wholesaler like this. have replaced the comm. bd and had them come back 2 life. tried the boot rom chip but that only helped a couple x. admit i have the luxury of bd swap.
        good luck jp
        IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
        THAN TO SPEAK AND REMOVE ALL DOUBT
        • vincent64
          • 382
          FIgured it out after lunch, ended up being the DC pwb, swapped it out, machine came up and is working.
          Thanks for the help
