AR-BC260 Missing Error code?
  • LaserSharp
    • Sep 2007
    • 94
    Forgive me If I'm missing it, but I've gone through the manual twice and am unable to locate a code a client called into the shop
    "CE" service?
    I'm on my way to check it out personally, and am hoping that either they read it wrong...or I'm just suffering from post 3 day weekenditis, as I have found no mention of this code in the manual.
    As always, any help is appreciated.
  • MHeon71
    • Oct 2008
    • 489
    You may just have to clear 24-4 - color maintenance. To make sure, you can go into 21-1 to find out for sure what the color PM is set for, it should be 50K. But for you to read it for yourself. Page 10-10 1/3 of the way down the page, it tells you what the first digit stands for C=color and then the second digit E= 50K.
    • ZOOTECH
      Senior member of CRS
      • 3375
      CE error codes can also be for network scanning issues.
      • mansart
        • 852
        CE codes are scanner communication errors.........
        CE-01 The optional network interface card (Print Server Card) is not installed or is out of order.
        CE-02 Cannot find the specified mail server or FTP server.
        CE-03 The server was down during the scanning of the original.
        CE-04 An invalid account name or password for the FTP server has been entered.
        CE-05 An invalid directory of the FTP server has been entered.
        CE-00 An error other than the above has occurred.
        • mansart
          • 852
          These are straight from Sharp.........no I did not make up the CE-00
          • Dark Helmet
            • May 2009
            • 846
            Don't worry about the code! Just dowse the machine in fuel and burn it down! Save you a bunch of headaches later on.
            I was on the phone with Sharp once for help on one of those machines and i said "This machine does not like me." He replied with "Those machines don't like any body."
            • LaserSharp
              • Sep 2007
              • 94
              thank you all for the advice, it turned out that they had misread the code, or it was mistranslated to my work order...etc.
              I do appreciate the feedback from you all though, since apparently if it HAD been the correct code, there was stuff I was missing in the manual.
              As for dousing it in fuel...I must admit that after nearly slicing my fingertip in half replacing a developer driver gear on one of these, the thought had occurred.
