Does anyone know if it is possible to turn off the usage status message that appears on the lcd screen when using pin codes on the MX4500. I know it can be done on the new range of MX's, but can it be done on the older range?
Ive had customer complain about the 6 second message that shows how many copies are made on the account. I do not remember seeing a a spot to disable that but you can turn it to 1 second and it's gone pretty fast. By the time most customers have hit the OK button to login and move their hand to the start button the message is gone
It in the system settings under admin mode. after you get in as admin on first screen is operation settings button (top right box) select it. In op settings window is display message time. defaulted to 6 seconds, change to 1.
