MX 4500 usage status window
  • hammer
    • May 2008
    • 111
    Does anyone know if it is possible to turn off the usage status message that appears on the lcd screen when using pin codes on the MX4500. I know it can be done on the new range of MX's, but can it be done on the older range?
  • Dark Helmet
    • May 2009
    • 841
    Ive had customer complain about the 6 second message that shows how many copies are made on the account. I do not remember seeing a a spot to disable that but you can turn it to 1 second and it's gone pretty fast. By the time most customers have hit the OK button to login and move their hand to the start button the message is gone
    • hammer
      • May 2008
      • 111
      Thanks for that. Is it a SIM code to change it? If so, can you point me in the right direction?
      • OMD-227
        Lawrence is correct (as always). The default is 6 seconds. Every run-up we did was changed to 1 second, so we never had any complaints.
        Log into system settings as administrator, then find operation settings. Its in there.
        Good luck.
        • DavePo
          • 305
          It in the system settings under admin mode. after you get in as admin on first screen is operation settings button (top right box) select it. In op settings window is display message time. defaulted to 6 seconds, change to 1.
          • hammer
            • May 2008
            • 111
            usage status window
            Thanks guys. Thats fantastic! Just seen it. Lets hope it sorts things out. Thanks again.
