interchangable feed rollers
  • Dark Helmet
    • May 2009
    • 868
    Just out of curiosity do any of you guys use feed rollers from the newer generation machines in the older ones?
    ARM237 had a green feed tire and when ARM257 came out it was grey. I think the pickup part# changed to. One day i needed rollers for a ARM237 but i did not have enough so i used rollers for the ARM257 and ive never had to go back. Same thing for the ARM350 vs the ARM355/MXM350. The rollers in the trays have differnt part numbers, the treads look a little bit differnt but i can't see why they would not work.
    Does any body have any good/bad thoughts on the matter?
    I like standardizing parts, fewer items means less to track down at inventory
  • DavePo
    • Jul 2008
    • 305
    We use AR310IR for all of the ARM208 through AR317, MX850RT(Hercules Rollers) for all of the Dragons, Pastels 1 &2, C-dragons & Jupiters. We use theNROLR1508FCZZ and NROLR1509FCZZ on the MXM450N back through the ARM280N. We do not have any issues.
