I went out to this copier for a F1-87 which is stapler motor. Customer said copier had been in storage. I asked if they had tried resetting the copier they said yes. So I reset the copier and it works. Not sure if this problem could be related to being in storage or resulting from the move from storage to their office??? If problem persists can either the sorter be removed or set copies to exit from the internal tray??? I know that this copier can be connected to print. How about scanning??? The only printer connection I saw was a parallel port???
Thanks!!!
Thanks!!!
