MX2300N Original size detect
  • gwaddle
    • May 2009
    • 782
    Have an MX2300 That will not detect original size off the glass. Just says load 11x17 paper. Any ideas about the most likely cause?
    I know I should be ashamed of myself. Strangely though, I am not.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Have you ran TC 41-1 to see if your PD sensors are working? Try running TC 41-2 document size sensor sensitivity adjustment. If this doesn't work, you may have bad PD sensors.
