sharp arm450
  • sam234
    • Oct 2009
    • 10
    sharp arm450
    hi
    every one can someone help me am a newbie here ............ my sharp arm450 copier . when coping with the adf passer it cant copy front and back at he same time it give black or black at one side of and copies the other side.
    • 23008
    All the common problem will require a technician.
    The SPF may be misaligned on the copier. There may be a problem with the CIS unit or the main SPF harness.
    My best advise to you is to hire a competent copier technician to solve this problem for you.
