AR M550/620
  • patwilf
    Service Technician
    • Nov 2009
    • 41
    AR M550/620
    Having problems with the AR621NTBA waste toner backing up in the cartridge, and locking up the whole system. But the cartridge is still 30% full.......ANYBODY ELSE SEEN THIS?????????
  • ZOOTECH
    Senior member of CRS
    • 3375
    http://www.copytechnet.com/forums/sh...arm-620-a.html
    This should help explain what's going on.
    • OMD-227
      A quick search of this forum would show you several posts on this subject (there have been several lately).
      Basically the problem is either related to environmental conditions, old-type toner cartridges in use, tech not performing service correctly & resetting service rotation counts, old firmware versions on machine, service adjustments not performed in simulation/service mode or a failure to properly clean the waste toner piping from last problem occured.
      If you are a tech, I can provide you with everything you need. If you are not a tech, get one!
      • patwilf
        Service Technician
        • Nov 2009
        • 41
        reply
        thanks for the help guys....i'll pass this along to my service manager.....
