Having problems with the AR621NTBA waste toner backing up in the cartridge, and locking up the whole system. But the cartridge is still 30% full.......ANYBODY ELSE SEEN THIS?????????
AR M550/620
"You can't trust your eyes, if your mind is out of focus" -- -
OMD-227
A quick search of this forum would show you several posts on this subject (there have been several lately).
Basically the problem is either related to environmental conditions, old-type toner cartridges in use, tech not performing service correctly & resetting service rotation counts, old firmware versions on machine, service adjustments not performed in simulation/service mode or a failure to properly clean the waste toner piping from last problem occured.
If you are a tech, I can provide you with everything you need. If you are not a tech, get one!Comment
