AR-EF3 multi-feeding
  • MHeon71
    • Oct 2008
    • 489
    AR-EF3 on a ARM455N is multi-feeding. I just replaced the seperation pad fixing plate per MFP-TB-333 for paper jamming. Seperation pad fixing plate angle has change by like a degree. Now it is multi feeding. Anyone else run into this.
    • 23009
    There are a dozen posts at least on this subject. Try a 'Search'.
    • MHeon71
      • Oct 2008
      • 489
      I just removed the modified part per MFP-TB-333, and installed the original part. I was never a fan of any of the seperation on the EF1 or 3.
