Web setup for ARM350N
  • Peter Sim
    • Sep 2008
    • 445
    Hai all, need help.
    I want to delete the networkw scanner address,i open up the Network scanner tool>web setup>Destination Management>it pop up the user name and password box,after i cancel, it show "401 Anthorization Required"
    Is my copier or pc need to log in password and how to clear?Any idea?Thanks.
  • bilyahn
    • Dec 2006
    • 1470
    When you go to destination management these are the logins
    Login: admin
    Password: Sharp
    Also be sure NOT to be in image send mode on the copier or you will get an error message when you go to submit your request. Can only delete one entry at a time.
    Good luck.
    Bil
    • Peter Sim
      • Sep 2008
      • 445
      Login: admin
      Password: Sharp
      Good luck.
      Bil
      Thank you Bil for your reply.
      When i login with the "admin and sharp" it still the same, it will not allow me to login.Any other way ?Thanks
      • bilyahn
        • Dec 2006
        • 1470
        Try admin and admin. On the Sharp password in it has to be a capital S.
        Good luck.
        • Peter Sim
          • Sep 2008
          • 445
          Good luck.
          Thanks for your reply.Yes,i put capital S on the sharp password.Can i clear the Simulation 88>7> Scanner all memory clear ?
          Thanks.Would it help to clear the password?Or it will clear the whole scanner?
          • bilyahn
            • Dec 2006
            • 1470
            I'm sorry I can't help you there. I've never had to reset the web password before so I'm not sure if that will work. Did you try to reset the NIC? I looked at the ARP20/21 SM and there is nothing about it there.
            Please let me know if that works or not.
            Good luck. Bil
            • lky1978
              • Mar 2009
              • 483
              Custom setting >key operator program>printer setting> network setting >default
              • Peter Sim
                • Sep 2008
                • 445
                Thank you lky1978 and Bil.
                I just set it to factoy default and all the address has gone and when i go to web setup the password still appear.
