Sharp AR 405 HDD replacement
  • nmfaxman
    • 1702
    Tried to replace the HDD from an AR407 and it didn't work.
    Are the hard drives proprietary?
    Getting Code F2-37.
    Help.
  • ZOOTECH
    Senior member of CRS
    • 3375
    F2-37 ??? is a drum mark sense error, not relating to the HDD. Try running 44-2 to adjust the DM gain, then clearing with TC 14.
      • 23009
      I agree. Clean the surface of the drum mark sensor and ID sensor. Run 44-02 to re-calibrate the drum mark sensor.
      In a few rare cases I know of the wrong type of drum being installed, or a wear mark through the drum mark has caused this same code.
      • nmfaxman
        • 1702
        Sounds like another case of HIROSHIMA! Fix one thing and another pops up just to cause me grief.
        Thanks for the input, I'll let you know if it works.
        • adel_nagieb2000@yahoo.com
          • Jun 2009
          • 14
          Getting Code F2-37.
          Help.
          no f2-37 the toner box but the hard is getting e7-02 i thank that you can replase the toner box and see the result
