ARM277 Maint. Schedule
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    I think I originally posted this in the wrong forum:
    We're taking over service on a Sharp ARM-277 and I would be most appreciative if someone could send me the service manual or at least the scheduled maintenance cycle for the machine. I worked on these years ago, but can't remember the exact numbers for each consumable. Thanks in advance for your help.
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
  • rh112
    • Dec 2007
    • 51
    Drum 75K
    Developer 75K
    Upper Heat Roller 150K
    Lower Heat Roller 300K
      • 23009
      If I can add to rh112's comments:
      150k PF rollers
      150k two-stage fuser coupler gear
      75k fuser felt (if you don't change the felt the upper roller won't make 150k)
