Part no-toner,drum,developer,cleaning blade for Sharp AR-5316E
  • Dimpo
    • Aug 2009
    • 104
    Hi
    I am looking for the part numbers for the following iterms,Toner,Drum,Developer and cleaning blade for Sharp AR-5316E.If possible help me with the prosidure to enter simulation,when i want to enter simulation the time i enter 20 and then start the machine start copying
    Best Regards
    Dimpo
  • xeroxsharp
    • Nov 2008
    • 270
    UCLEZ0009QSZZ cleaning blade
    Middle East / Africa / Philippine
    NO Name Content Life Product name Remark
    1 Toner cartridge(Black)
    <With IC>
    Toner
    (Toner: Net Weight 537g)
    Vinyl bag
    x10
    190K AR-016ET Life setting by A4 6% document
    ET=FT*10
    2 Developer Developer
    (Developer : Net Weight 400g)
    x10 500K AR-202CD CD=SD*10
    3 Drum fixing plate
    x1
    50K AR-202DR
    1. Entering the simulation mode
    Perform the following procedure to enter the simulation mode.( follow the step and be faster than two seconds)
    "#" key; Interrupt key; "C" key; Interrupt key
    Main code Start key Sub code Start key
    20 1 Maintenance counter clear
    42 1 Developing counter clear
    24 7 Drum counter clean
    • Dimpo
      • Aug 2009
      • 104
      Sharp AR-5316E
      Hi
      Thanks for the help but my machine still can not enter into simulation.The time i enter 20 then press start it starts copying.Any help?
      Best Regards
      Dimpo
      • spotlifter
        • Mar 2008
        • 65
        If you have success entering into simulations, the display will be blank. No "zero" or no numbers. Try entering with super speed .
        sigpic
