copy density
  • Peter Sim
    • Sep 2008
    • 445
    copy density
    Hai all ,I am new to the sharp machine
    Need advice for AR-M350 copy density adjutment.
    1) can we adjust simulation 8-1,2 and 46-2,9,19,11 ?
    2) For auto exposure,what simulation code that need to adjust to make it darker?
    Thank you.
    • 22942
    Assuming that your consumables are in good shape, use Gamma 46-18 for the majority of your correction. In extreme cases I have boosted gamma as high as 100 from the default of 64. It affect both AE and manual exposure.
    Most of the new machines that left our building were boosted to around 80 at setup. You can fine-tune the density with 46-2.
    Now if you go crazy with these adjustments, creating excessive fill, you'll shorten the life of the drums & developer, and start consuming considerably more toner than the stated yields. The machine will run extremely dirty. So you'll want to use some judgement. You can create a lot of future service calls for yourself this way. =^..^=
    • Peter Sim
      • Sep 2008
      • 445
      Thank you blackcat for your kind reply and info.
      • BrazilBoy
        46-19= switch from 2 to 1 as 2 is toner quantity dependent go to 1 to use digital only..this helps quite a bit..
        Also new tech with old copier run a 22-6 go down the list of 46 adjustments you don't know if someone was porking with settings before you got to it..when in doubt put everything to factory settings and go from there..Just run that 22-6 before anything...
        Also clean everything in any copy machine you would be amazed what a good mirror and laser lens cleaning can do...
        Later Roberto
        • Peter Sim
          • Sep 2008
          • 445
          Later Roberto
          Thank you BrazilBoy.
