Sharp ar 5320e e7 sub 2 trouble
  • Johsel
    • Mar 2009
    • 9
    Good day!!! I have a problem w/ one of my client, lately their machine was infested by ants. I found so many ants in the lsu unit. So i have no choice but to removed ants and cleaned the lsu unit but when i return the unit a trouble of e7 sub 2 appear. I checked the rotation of the polygon motor and its rotating. Sim 61 sub 3 has problem,, does it mean that laser pwb was defective? If so, is there any remedy with it? I have encountered this ants problem with this machine twice and i made the same procedure but lately i didint suceed .... Is there any remedy or should i advise my clients to replace the lsu unit? Thanks for your intelligent response>>>>
    • 23009
    I've got a guess that you might have a beam detect condition. When you cleaned the laser did you specifically clean the beam detect mirror & receiver? Did you clean the laser diode and lenses? I suspect that the mirror motor is fine, because you'dd have a L6-10 condition. Also check that you properly seated all the lenses, mirrors, all those precisely positioned components in the laser unit. =^..^=
