E1-00 code on Sharp AR-168
  • ebm
    • Apr 2007
    • 183
    Anyone have a fix for this code? Turning off/on does not reset.
  • nightshade
    Chromographic Supremesist
    • 158
    Being at home and not looking it up, my first thought is replacing mirror base "A" otherwise called the scanner assy.
    But you could try reseating all the connections for the scanner especially the flat cable.
    • cucuklotz
      • Mar 2007
      • 611
      HI,
      Have you tried resetting by a crop 14 simulation?
      Press Clear key, Interrupt key," 0 "key, Interrupt key,(display should go blank)Press "1" key ,press "4" key ,press start key.
      Hope this helps, ANDY
      • ebm
        • Apr 2007
        • 183
        Tried Sim 14 to reset, no joy. Also, tried to install firmware w/o success. Ended up replacing MCU PWB from another machine. Anyone, know the procedure to reprogram counts (total,pm,dv,drum)?
        • just a tech
          • Jan 2007
          • 333
          this is from the ar-162,165,207 models ut will more than likely cross over to the ar-168 as well..they are in sim 24..
          24 01 Jam total counter clear
          02 Trouble memory clear
          04 SPF counter clear *2
          05 Duplex print counter clear *6
          06 Paper feed counter clear
          07 Drum counter clear
          08 Copy counter clear
          09 Printer counter clear
          13 Scanner counter clear
          14 SPF jam total counter clear *2
          15 Scanner mode counter clear ..hope this helps. good luck
          • nightshade
            • 158
            By chance is it a AR-168D?
            • ebm
              • Apr 2007
              • 183
              Yes, it is a AR168D. Sorry for the confusion. I do not need to reset the counts to zero. I need the procedure to program the counts from the old board to the new one.
              • nightshade
                • 158
                Got an email address?
                • ebm
                  • Apr 2007
                  • 183
                  Thanks to all who replied. Reached out to another dealer in my area and got the info to reprogram the counts.
