AR160 toner end indication
  • toshiba
    • Dec 2006
    • 58
    Dear friends,
    I'm facing "toner empty" indication in AR160 even after installing new cartridge. By changing the sensor chip in the cartridge doesn't solve the pbm. Simulation mode 14,16,25-02 also didn't work out. PLEASE HELP!!!
  • Comingapart
    • Jun 2008
    • 44
    This is a TD cart unit, correct? with the toner and dv in one cartridge?
    If so, look in the process area at your toner motor shaft. It's probably broken.
    • bilyahn
      • Dec 2006
      • 1470
      There is a tech bulletin concerning this and Sharp put out a new part to take care of the problem.
      RMOTD0016QSZ1
        • 23009
        bilyahn is right. This is a very common problem on the Panther. By now, most of those machines have the modified toner motor with the metal shaft (not plastic). This must be a very low volume machine. =^..^=
        • toshiba
          • Dec 2006
          • 58
          dear friends,
          thanks for your suggestions. I forgot to mention one thing. This is not a hardware related complaint. By repacing the EEPROM, its working. But is there any way to reset the EEPROM?
