mxm350n misfeed /stapling
  • spokc
    • 35
    the stapled set doesn't deliver causing misfeed, it is an intermittent problem the finisher arn6 was
    swapped but problem still persists
  • OMD-227
    Jam codes please.
    There are no bulletins which I can see on this issue as yet, so we will need the jam codes for further assistance.
    • spokc
      • 35
      jam codes
      don't know
      • Comingapart
        • Jun 2008
        • 44
        we need more specifics.
        jam codes, any error codes in the history, meter, was the fn6 you swapped a new one or used one? Where does the paper stop at?
        • OMD-227
          Let it go Michael..... If this guy cant help us, how can we help him??
          • spokc
            • 35
            not always here to see threads
            the stapled set is stapled and the exit rollers turn but do not deliver
            don't know the jam code
            its intermittent
            it can happen when running one set or many
            • spokc
              • 35
              the swapped finisher was used
              but had no problem before
              • OMD-227
                jam codes, jam codes, jam codes........ get us the jam codes when next at the machine.
                • spokc
                  • 35
                  staplin problem
                  ok
                  • bilyahn
                    • Dec 2006
                    • 1468
                    If your copy is stapling and then getting jammed you can check the tension on the belts in the finisher and clean them depending on use. There is a tech bulletin out for this. Also if it pushes the copy out about an inch and then jams the flag that is on the output of the tray can become stuck (sticky). I have had both of these situations occur with the FN6 in offset or staple mode.
                    Good luck.
                    Bil
                    • spokc
                      • 35
                      thanks i"ll check that
