Toner Problem with Sharp AR-C 170 and 172M
  • vonhetcchtel
    • 42
    Please, can some one out there tell me what to do with my machines.
    My customers machines are always asking a Change of Cartridge when the Toner has been used up.
    I have tried to refill Toner after this message but it is still repeating thesame message. What am my really going to do with this machines?
  • vlad_
    • Jul 2008
    • 98
    after replenishment cartridge must be replaced by the chip.
    • sarcopy
      What is meant by "replaced by the chip"? I have a similar problem with AR-161 copier--replinished cartridge but "cartridge" light still on.
      • OMD-227
        Are you serious?
        • vlad_
          • Jul 2008
          • 98
          In the copier AR-161 is not the chip!
          It is possible that not spinning DV unit or a broken axle in the toner motor. She was there made of plastic and often break down.
          • sarcopy
            Many thanks for your helpful suggestion. Actually I got it working fine after rotating the mg roller a few turns--that plastic gear is still intact and in good shape.
