copy flash rooms ar-450n
  • DINGO
    • 661
    Good night
    Anybody knows how, using the own copier arm-450 do a copy of the flashs, pcu, icu and so??
    There are some guide of this?
    thanks
    • 22999
    Take a look at this:
    • DINGO
      • 661
      hello
      wazza
      think I did not understand because of my bad English, I know this kind of upgrade
      The point is that I have heard to make copies of flashes, in this copiers, without using pc,
      but using the machines themselves.
      I hope you understand
      regards
      • OMD-227
        Hey Dingo,
        I haven't sent you anything mate......?!
        Thats Blackcat's post above. Its the same as what I have. You can copy the roms in a whale, as I remember doing it a few years ago, but never tried in a tiger.
          • 22999
          That was one of my weekend projects. I took a old Tiger from the boneyard, and started removing stuff. I got the Tiger stripped down to a op panel, MCU, MFP PWB, DC power supply, line filter, main body harness, and a power cord. With these items strung together in a tangled mess on the table I could still copy Eeproms.
          Next, I stripped out the unnecessary parts of the main harness. The boards fit nicely into a plywood box 10"H x 12"W x 24"L. The op panel fit onto the top front, the MFP in it's little metal cage fit in the front face, the cord out the back, and a fan fitted into the top for cooling.
          I called it "Tiger in a Box". It's still sitting on the workbench at my last employers office. I'm sure that noone has any idea what to do with it.
          Dingo, you're going to have to figure this out for yourself. Read the bulletin again and try it out. Remember that the Tiger can copy EEPROMs with white lettering (leaded solder boards), but not EEPROMs with yellow lettering (silver solder boards).
          • DINGO
            • 661
            re
            SORRY,
            I meantBlackat,
            I will now translate the blackat coment
