AR-337 H-3-00 error code
  • Lawton
    • Jun 2025
    I think its going to be the sub lamp in the fuser, can anyone help? Thanks
  • Copier Systems
    Fuser reset
    Try sim 14 .15, to see if it resets if no reset start cking fuse in fuser,lamp thermister
    Andy H. Sim 14 or Sim15
    • Lawton
      Thanks for the info.
      • choicecopyguy
        • Mar 2006
        • 111
        H-3 00 is high temp detect. If sim 14 does not reset, check with sim 5-2, the fuser lamp should blink on and off, if it does bad thermistor, if not bad control pwb.
          • 22995
          buildup on thermistors
          If it resets then re-occurs, clean or replace the thermistors.
