I have been an IT guru for 15-20 years....lots of hardware, networking, etc. Limited work on printers. I have a AR-M350U (Sharp), that I need to change a drum on. I have the assembly out. Is there a trick to changing the drum itself? Thanks!
How to change drum AR-M350U
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
Paul@justmanuals.com -
OMD-227
I agree. If you are just getting into changing consumables and hardware, get yourself the service manual, as there is alot more to just changing a drum over, such as maint kits, sim changes & resets.Comment
you can work for many year with any hardware but for that photocopy just some day, so you don't understand anything about this photocopy machine, if you want change the drum on should call tech do this for you or buy service manual and par-part and learn yourself how to do that with some risksComment
I have to agree about getting a service manual. While replacement of just the drum is a mater of a couple screws, there are other standard maintenance parts/processes done at the same time like changing the cleaning blade, cleaning out waste toner and other things that may not be all that obvious - even to a self-professed guru.Comment
if you get a sharp ar451dr drum make sure you do SIM44-1 like it says on the box in addition to resetting the counters to avoid problems. you also need to go into SIM21 and change the cycle to 100K. Just an FYI thats not in ther service manual.Comment
