Scan to email
  • Peter Sim
    • Sep 2008
    • 445
    Scan to email
    Hai all ,
    Need help and advice.
    How to configure scan to email on AR-M450 ?
    Where to set the port number ?
  • spotlifter
    • Mar 2008
    • 65
    Hi, Peter.
    As far as our country, most local company can't afford their own private servers and bandwidth speed limited.
    So, it is difficult to setup scan-to-email for them. Unless your customer is a big company and has their own servers.
    For what I do was, scan to PC desktop and manually attach document to emails. It's pretty much the same. Only extra 1 step.
    And I'm sure there are already pretty much alot threads regarding this setup. Why don't you do a little search around the forum.
    sigpic
    • costd
      • Jan 2008
      • 409
      If you have the N model, use the RUI to: Setup>Network Settings>E-mail. HOWEVER - We normally just use their copies of Sharpdesk as most people would like to send a note with the attachment.
      • Peter Sim
        • Sep 2008
        • 445
        Yes ,is N model. How about the port number? Our port number right now is 2525.
        Originally posted by spotlifter
        Hi, Peter.
        Thank you for your suggestion.From the web page,they know there is scan to mail function,so they need the feature.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1885
          The AR-M450 doesn't have a place for authentication (username & password) for SMTP. Unless the mail server will allow an unauthenticated connection (most will not) you'd have to get a program to relay it. You could try www.stunnel.org It will encrypt the connection, not sure about adding authentication. Like the previous poster stated, scanning to Sharpdesk might be the best way to go.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • df3036
            • 109
            I have used this at our office, but not in the field.
            [Tutorial] WinXP Local SMTP Relay server - WESP
            Works well as relay...
            Kittens give Morbo gas.
            A+, Network+, Server+, PDI+
            • Peter Sim
              • Sep 2008
              • 445
              Thanks for both of your suggestion,tmaged and df3036
              • soonerfb06
                I have recently been trying to figure this out. I have been working with a ARM280 with no luck. Like the earlier poster said they don't have the smtp authenication. But Does anyone know how to scan to a Macintosh with this series? We have tried to create an ftp folder on the mac with no luck.
                • bilyahn
                  • Dec 2006
                  • 1470
                  The only way that I have gotten it to work with Macs is to use the scan to email feature but I am using an ARM455N not the older series.
                  • tmaged
                    • Oct 2008
                    • 1885
                    Yep, the 455N has authentication for email where the 450N doesn't.
                    Hope that helps !
                    -Tony
                    www.dtios.com
