Sharp AL-1540
  • GottaFixEmAll
    • Jun 2007
    • 55
    Sharp AL-1540
    E7-11 code ... CCD White Level Trouble: CCD drive circuit (CCD PWB, ASIC harness) trouble Copy lamp lighting trouble (Copy lamp, inverter PWB) .................
    This machine has been on my shelf for months with this code ... decided to install the scanner and cable from the 1655cs that I had problems with previously (customer doesn't want to fix it), anyway ... the 1655cs scanner and cable worked fine on the other machine (when it fed a sheet of paper !! ).
    Unless I'm missing something .... and thats possible !!, I'm presuming that the scanner and cable are good and that there may be a problem with the 1540's main board !!
    E7 codes also list laser codes ... although separate ... could the laser be causing this ???, I have never heard it spin-up ??? ................
    Thanks ..................... Mike P.S. I do have the manual
  • bilyahn
    • Dec 2006
    • 1470
    You might want to check the levelness (word?) of the scanner carriage. I have had some issues with this but don't remember if it caused a E7-11 or not.
    Good luck.
    Bil
