AR BC260 Image quality
  • iscott
    • Mar 2010
    • 344
    I have a Sharp AR BC 260 with 2 image quality issues
    1) Gray faint lines every 3-1/4 inches apart (drum is my guess)
    and
    2) Image drop out which can best be described as part of the image looks like an old generational copy but some of the document is very clear (not perfect but clear)
    They have been using this copier as a black and white unit only for a couple of years.
    Well any ideas?
  • vincent64
    • 382
    and
    Well any ideas?
    What kid of maintance has been done, transfer belt, drums, also the gears that drive the toner cart in there, if they are cracked, could all be at fault.
      • 22996
      Search "Sharp gears". There are at least 6 post that cover this topic quite thoroughly.
      http://www.copytechnet.com/forums/sh...320-lines.html =^..^=
      • sadj
        Yeah thats right........drum drive gears crack. Replace & add the washer too. That should cure it.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
          Paul@justmanuals.com
