Sharp MX3501N
  • b1gv1c
    • Jul 2025
    Sharp MX3501N
    Getting Maintenance Code DK constantly flashing. What does this code mean?
  • ZOOTECH
    Senior member of CRS
    • 3375
    The black drum counter has reached it's limit of 150K of the drum rotations has reached 840K. Time for a PM; other codes might show up soon after drum replacement and counter clear.
    • b1gv1c
      What is needed. The drum unit?
      Genuine Sharp MX3501N Drum (G9828)
      • ZOOTECH
        • 3375
        Yeah, that's the one and the best way to replaced those drums (as a unit) rather than just the drum, blade ,and MC.
        • b1gv1c
          Excellent! Thank you for your quick response!
          • OMD-227
            Usually, the fuser web is due at the same time as the K drum, as its on the same 150K counter. When you change the K drum unit, you are going to have to check all counters in 22-1 and 22-13 to make sure nothing else is due or near-due. Make sure the firmware is up-to-date.
            • b1gv1c
              clearing the error
              How do I clear the error? Code:dk
              • OMD-227
                Are you familiar with Sharp machines? Is this your only Sharp machine? You should be getting yourself the service manual, as there is alot more to these machines than just replacing something & resetting it.
