Copying to envelopes on MX3501
  • gwaddle
    • May 2009
    • 782
    Does anybody know a way to copy onto envelopes on an MX3501? Or can you print from a flash drive? The machine is in a place where they can't hook a computer to it to print directly. Or could I scan to the HDD and print from there?
    I know I should be ashamed of myself. Strangely though, I am not.
  • Copier Doc
    • Mar 2010
    • 49
    You can print directly from usb but only Jpeg files & they cant be inside a folder.
    To print pdf etc direct from usb you need postscript option installed.
    As for the envelopes why cant you just put them in the bypass?????
    • gwaddle
      • May 2009
      • 782
      The envelopes are in the bypass, and with the bypass set to envelopes, if you put the envelope to be copied on the glass, it reads it as 81/2 x 11 and won't copy to the envelope in the bypass. If you don't set the bypass to envelope it will copy by will only scan about 1/2 of the original. There has to be a way to do this.
      • ZOOTECH
        Senior member of CRS
        • 3375
        I'm not sure it will work, but login as administrator for system settings. Go to Device Control, and select Original Size Detector Setting. On the last page put a check mark in Cancel Detection at Document Glass. It shouldn't read the envelope as 8.5x11 now. You just have to remember to un-check the box when they have finished copying envelopes.
        • gwaddle
          • May 2009
          • 782
          Thanks Zootech, that was one of many things I tried, it didn't work. I don't know why they made this so difficult. I think I hurt my brain on this one.
          • gwaddle
            • May 2009
            • 782
            I don't know why, but, disabling offset allowed envelope printing. Thanks for the replies.
