E7-11 on ARM-276
  • vlad_robas
    • Oct 2006
    • 225
    E7-11 on ARM-276
    Hello,
    Tsi machine it has about 500k and is used for scanning and faxing alot it has been shown this code in the past too but the people that ar using it said that they turn it off and back on and the error disapeard. Today they caled me becouse what they scan isn't looking good enought in PDF. I cleaned glass and mirrors and done some testing, error apeard and dispear afther taking off the glass and putt it back. Glass and mirror's didn't had dirt or dust on them in the first place. Afther some testing all looked ok and i told them to scan at atleast 300 dpi for a better quality. Afther 2 hours they call me back couse error was back. I replaced the glass whith the white reference but the same code then i checked the flat cable end and put it back and it works but don't know for how long. Never had this kind of problem's what should i expect or order to replace?
  • OMD-227
    Make sure your firmware is current, also have a look at this bulletin info. I had this exact issue a few years ago and this was the fix.
    • vlad_robas
      • Oct 2006
      • 225
      Thank you.
      I will try that if get another call on this problem or on next 2 week's when i have to go read counter's.
      • efe311
        • Oct 2008
        • 114
        Try to clean the mirror & the white refrance
        • vlad_robas
          • Oct 2006
          • 225
          What is wrong with u? efe311 why do u have to reply and say obvious thing's that have been already sayid.
          • OMD-227
            Well said Vlad. Sometimes the obvious is oblivious.
            • xeroxsharp
              • Nov 2008
              • 270
              From my experiance: Few times in ARM 207- Cleaning optic or replaceing exp. lamp and reflector fixed E7-11(problem only in colour scan
              200 dpi and up )
              Once in AR 275 on copy mode, but it takes time to solve this - cleaned everything not good,replaced exp.lamp and flat cable
              but stil not good, replaced lamp unit not good again, than replaced lense unit and fixed E7-11.
              On ARM 276 never seen this error before.
