Sagem mf-9327 toner chip
  • efe311
    • Oct 2008
    • 114
    [Electrical] Sagem mf-9327 toner chip
    I HAVE THE DEVICE THAT CAN CHARGE THE TONER CHIP FOR SHARP COPIERS BUT THAT DEVICE CAN NOT READ OR WRITE ON THE TONER CHIP FOR SAGEM COPIERS
    NOTE :
    THE SAGEM COPIER MF-9327 THE SAME OF SHARP AR-M276
    WHAT CAN I DO FOR THIS PROBLEM
  • DINGO
    • 661
    Hi
    I have several sagem 9323 , i flash it whith firmware sharp ar-m236 and after acepts very good the toner, and chipr toner sharp.
    good look
    • OMD-227
      good look
      Precisely why you have so many problems with weird trouble codes Dingo! Remember your U1-01 issue!
      • DINGO
        • 661
        • OMD-227
          Its all good mate..... just stirring the pot.
          I'll be leaving the re-flashing of brands to you. You seem to be the master of it.
          • efe311
            • Oct 2008
            • 114
            Many thnx i try that & it's work thnx again
            • efe311
              • Oct 2008
              • 114
              Hi
              good look
              • DINGO
                • 661
                Hi
                trhe sagem after change the firmware by sharp, work whith the two toner chips, sagem and sharp.
                regards
                • efe311
                  • Oct 2008
                  • 114
                  yes i flash it with sharp firmware & its work very good
