Sagem mf-9327 toner chip
  • efe311
    replied
    yes i flash it with sharp firmware & its work very good
  • DINGO
    replied
    Originally posted by efe311
    Many thnx i try that & it's work thnx again
    Hi
    trhe sagem after change the firmware by sharp, work whith the two toner chips, sagem and sharp.
    regards
  • efe311
    replied
    Originally posted by DINGO
    Hi
    I have several sagem 9323 , i flash it whith firmware sharp ar-m236 and after acepts very good the toner, and chipr toner sharp.
    good look
  • efe311
    replied
  • OMD-227
    Guest replied
    Its all good mate..... just stirring the pot.
    I'll be leaving the re-flashing of brands to you. You seem to be the master of it.
  • DINGO
    replied
  • OMD-227
    Guest replied
    good look
    Precisely why you have so many problems with weird trouble codes Dingo! Remember your U1-01 issue!
  • DINGO
    replied
    Hi
    good look
  • efe311
    started a topic [Electrical] Sagem mf-9327 toner chip
    I HAVE THE DEVICE THAT CAN CHARGE THE TONER CHIP FOR SHARP COPIERS BUT THAT DEVICE CAN NOT READ OR WRITE ON THE TONER CHIP FOR SAGEM COPIERS
    NOTE :
    THE SAGEM COPIER MF-9327 THE SAME OF SHARP AR-M276
    WHAT CAN I DO FOR THIS PROBLEM
