Mxc401 error main black rear 56
  • gwaddle
    • May 2009
    • 782
    When running 50-22 sometimes get a MAIN BLACK REAR 56 error. Also the skew numbers are all over the place. If you try to adjust for the skew it might throw it off a whole different direction. On the Main Black error, I know what the book says, but haven't found what to do about it. Can someone point me in the right direction?
    I know I should be ashamed of myself. Strangely though, I am not.
  • ZOOTECH
    Senior member of CRS
    • 3375
    How is the image skew in 61-4? That is where you should start, and if 50-22 is way off, I'd run 50-20 and 50-21 to bring it into specs than run 50-22 again to nail it.
    • gwaddle
      • May 2009
      • 782
      Thanks. I always start with 61-4 and the skew is good there. Ran 50-20 and just to try something, set all to default. Of course when I ran 50-22 again all the 50-20 settings changed, they are anywhere from 81 to 134.
      • ZOOTECH
        • 3375
        Sorry Gene, I got my models crossed, there is no TC 50-21. In 50-22 how far off are the NG colors?
        • gwaddle
          • May 2009
          • 782
          Anywhere from 10 to 40 and they change every time you do it. I've seen them go from +30 to -20.
          • ZOOTECH
            • 3375
            On earlier models, the adjusting screws would not engage the cams sometimes and cause either wide swings or no adjustment. I haven't had one of these apart yet, but could it be a mechanical problem?
            • wtroll
              • May 2008
              • 85
              Hi,
              if the error still occurs, maybe you have a problem on the Black Process Unit (dev. unit, drum or laser unit).
              Print a test pattern (one for each color) with 64-1 and check if quality is ok.
              And don't forget to clear the 2 image density sensors under the transfert belt (the rear sensor also detects registration shift on the machine rear side).
              Good luck!
              • wtroll
                • May 2008
                • 85
                Oops,
                the image density sensors are OVER the transfert belt...
                • gwaddle
                  • May 2009
                  • 782
                  I cleaned the density sensors and the code hasn't come back, but I'm still getting wild skew swings from the 50-22. Tried changing the black drum and dv units. No change. Any other thoughts?
                  • Dark Helmet
                    • May 2009
                    • 835
                    Never had the black error but ive had magenta errors.
                    enter sim 50-10
                    A = Black Mag
                    Every MX3100/4101 ive seen has always been set to 106
                    I can't remember if i changed it to 90 or 100 (try 100 first) but that got rid of the error. I was then able to run 50-22 and get a reading on which way i need to turn the screws and how many clicks.
                    I don't know if this is going to help for black as there is no adjustment screw on the black drum.
                    From what i understood from Sharp Tech support is this adjusts the view of the patches. I guess if it's "zoomed" in to much it can't see all of them? Not exactly sure but it has worked for the color phase/shift errors.
                    Something to try. Let us know!
                    • gwaddle
                      • May 2009
                      • 782
                      Thanks Lawrence, but this is an MXC401 and I think I got rid of the error, but the 50-22 skew numbers are still jumping around all over the place.
                      • Dark Helmet
                        • May 2009
                        • 835
                        It's the same procedure i believe
                        • gwaddle
                          • May 2009
                          • 782
                          It seems that a firmware update may have done the trick. Thanks for all the input. By the way, don't tell Wazza that I didn't think of doing firmware first.
                          • OMD-227
                            Ouch!
                            There's nothing in the full list of Frontier firmware revisions that have anything to do with fixing registration errors.
                            I have problems with rego settings on the Frontiers all the time, but it never really seems to affect any print quality. As the rego sensors are in a different location to the MX machines, and the belt assy is so flimsy & only screwed into place by half-turn thumb screws, I've always assumed the machine cannot put good patches down on the belt as there might be some very minor movement/shift in belt surface so the sensors cannot read it properly. I've never got a full answer from anyone else either on this matter.
                            I didnt chip in on this post as it is just something that happens, and everything I've tried doesn't make any difference. Nothing I could really help anyone with. But.... the machine works fine. Its just the rego numbers that are out and playing with my mind.
                            P.S. Do your firmware!!!
