Distinctive Ring
  • costd
    • Jan 2008
    • 409
    Distinctive Ring
    Machine is an MX-C311. No problem setting the fax for distinctive ring - except - there are 6 patterns to choose from. Since the phone company configured it for 2 short rings, I asked Sharp which of the 6 patterns available in the fax configuration woulod work. Their answer - do not know, try each of the 6 till you get the right one.
    Turns out I was lucky, pattern 1 worked. My question is - any of you have a list of what the 6 patterns are? I have the 4 from Canon, (and their #1 is same as Sharp - 2 short rings) but cannot find the Sharp list - even from tech support.
    Not a big deal, but "try them all" just does not seem professional to me.
    • 22997
    The FO-DC535 doesn't have 6 options, but this Operators Manual should be similar.
    • costd
      • Jan 2008
      • 409
      Thanks Blackcat - it helps. Kind of interesting as patterns 1-3 are the same as Canon. Perhaps it is a standard of some kind. Anyways, what you gave me is helpful.
