ARFX7 in arm-236
  • DINGO
    • 661
    ARFX7 in arm-236
    Hi friends
    I have a arfx7 in one arm-236, that whem try send a fax always give me "in waiting"? do not call.
    y alfeady do a reset and, the country is correct. (in 66-2)
    the option PBX is not enfable??
    can give me any idea?
    regards
  • OMD-227
    Haven't had that one before. Have you run 66-10 to reset the fax memory?
    • DINGO
      • 661
      re
      Hi friend
      no, i do not performd the 66-10, i try it tomorrow.
      i reset the fax by another kind.....
      thanks
        • 23006
        Hi DINGO.
        Does the machine dial? If yes, do you have any error codes on the activity report?
        Am I safe in assuming that this machine is from the Andromeda series? =^..^=
        • OMD-227
          Dave, its the same as your ARM237. We have it here as the ARM236 too.
          • rayjeek
            • Jun 2010
            • 239
            I have had a fax issue with ARM201 where by it can send but cannot receive. We provided ADSL microfilter and changed country of location of machine in Simulation to another country and it works fine. The machine was in UK but we changed it to New Zealand and that resolved the problem. Normally the settings are combination of 8 binary bits.
            • DINGO
              • 661
                • 23006
                I would try replacing the memory first, and if that does not help then the fax card. =^..^=
                • DINGO
                  • 661
                  Ok Blackcat4866, i wiil try.
                  regards, friends
