sharp AR-M350
  • adel_nagieb2000@yahoo.com
    • Jun 2009
    • 14
    sharp AR-M350
    I have amchine sharp ar-m350 the machine is connect the power but not opreate i saw the power fuse its off i change this fuse and conect the power
    the fuse broken again i change the main switch and the fuse but the fuse broken also please help me and thanks.
  • bilyahn
    • Dec 2006
    • 1470
    Sounds like you may have a short somewhere if the fuse keeps blowing. Have you removed the power supply? It is a pain to get out depending on your configuration but that is where I would start to see if you have a problem. I have had the fans that are located just above the power supply damage some of the wires that run through there.
    Good luck.
      • 23006
      I agree with bilyan. Most likely, there is some sort of short circuit in the power supply. A short on the low voltage side would not blow the main fuse.
      In this situation the smell test works well. If your power supply board smells like bacon, you probably will have to replace it. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • OMD-227
          I totally agree with the above, but also check the fuser unit. I had one a few years ago which had a pinched cable which was doing the same thing. It was a workshop rebuild fuser, and was working fine for 3 months, then decided to short out.
          (it wasn't my rebuild either!)
