I have MXM160D installed with two trays. Tray 1 feeds ok but tray2 does not feed.
On pressing the copy button, it tries to feed but never paper never pass the fuser. Paper will stop sometimes before registration area and sometimes in fuser. Upon jamming 'Clear jam from paper path' is indicated on screen. having cleared the jam and shut all doors/covers it feeds the current job on which it jammed. Just after the paper is fed, MFD stops indicating on screen 'Load A4 or A3 paper in Tray2'. depending on the paper loaded in tray2. Jam code is PIN2_ON. Today is the first time seeing this one, if you have had this before please share your thought.
