Enter Account Code----- Sf-2540
  • KHAN
    • Aug 2006
    • 261
    hi,
    i Have Sharp Sf-2540 Which Shows Enter Account Code-----
    i Dint Know The Code ,how To Reset Or Enter The Copy Mode,
    i Am New To This Copier, Some Body Enter The Code
    please Need Help?
    thanks.
    • 23010
    comparable to SF2040 US model?
    I don't know how much help I'll be, but lets give this a try.
    I'm assuming this model is an analog @ 40 cpm comparable to the SF2040 US model.
    Based on that, press orange Clear, Interrupt, 0, Interrupt, 26 on the numbers, Start, than look for a menu choice "AUDIT MODE", press that number then Start. The choices are usually '0' = off, '1' = on. Then Start, CA to exit simulation. I hope this helps.
    • KHAN
      • Aug 2006
      • 261
      Enter Account Code--------SF-2540
      thank You Friend I Will Try This And Let You Know,
      thanks For Your Help.god Bless You
      • ZOOTECH
        Senior member of CRS
        • 3378
        KHAN, if this is using the internal account control; enter the key op programs (clear-int-clear). Input your key op code and go to P10 to enable/disable account control.
