AR-C330 Error code f2-45
  • junker57
    [Error Code] AR-C330 Error code f2-45
    Got this copier but after moved it I know get this error worked fine before move F2-45
  • OMD-227
    There has been damage to the transfer belt and/or density sensor during the machine move.
    Under the transfer belt unit is a density sensor. Check the sensor, and also its moveable cover (solenoid driven). Make sure everything is seated correctly in there. During the move, its possible to have some toner spray on the density sensor.
    Check the cabling/plugs on the PCU sub board (at the front of the belt unit, behind the cover).
    Does the transfer belt have alot of color toner streaks running around it? If the cleaning blade has become damaged, it will not clean the belt surface, causing a poor reading of the density sensor.
    Run sim 44-02 to check density sensor operation.
