F2-40 on MX-M503
  • rayjeek
    • Jun 2010
    • 239
    [Error Code] F2-40 on MX-M503
    I have had F2-40 on two new delivered MFDs and the only fix was at a cost of replacing the dev tank and dev. I tried replacing only the dev first but it never resolved the problem. If anyone knows less expensive way of dealing with such issues and the cause, please advise.
  • android790
    • Jul 2010
    • 63
    Sorry. I never had that code on that machine. Talk to your setup people and see how they do the set up for it.
    Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
    • bilyahn
      • Dec 2006
      • 1470
      Do you happen to know what the developer reference value was on the bad developers or did it not work at all? I haven't had this happen yet so I am just wondering!! Here is a tech bulletin from Sharp regarding this. Hope it is helpful.
      Good luck.
      Bil
      • rayjeek
        • Jun 2010
        • 239
        Thanks Bilyahn for the info. I have had this fault code three times already.
        • bilyahn
          • Dec 2006
          • 1470
          You're welcome.
          • mojorolla
            The Wolf
            • 2627
            Tell the delivery guys to take the toner out during transit. As already mentioned, check the values first. If they are ok, got into SIM 7, turn off DV checking.
            Reboot, then run about 100-150 skyshots, until density is around 60. I have seen this a few times but only on the monochrome.
            • fanasa
              • Jul 2010
              • 34
              Here you go. I hope this helps
              To Prevent F2-40 Error Code at Set Up:
              Do not Install Toner Cartridge before performing Simulation 25-02.
              Do Not Transport the MFP with the Toner Cartridge installed in the MFP.
              Be sure not to over tone the DV Unit when you install the Toner Cartridge.
              When installing the Toner Cartridge after performing Simulation 25-02, be sure to insert it gently.
              Instruct the end user to gently insert any cartridges they install.
              Note:
              Inserting the Toner Cartridge forcefully can cause excess toner to fall into the DV Unit,
              lowering the TCD_K value. If TCD_K value falls below 26, F2-40 will occur.
              If you already have F2-40 Error Code recover by performing the following steps:
              1. Execute Simulation 25-01 and verify that the TCD_K value is less than 26.
              2. Execute Simulation 7-1 and highlight [DV Check Disable].
              3. Open the Doc Feeder.
              4. Place a piece of white paper in the lead edge area of the platen glass covering about 1-2
              inches of the lead edge area of the copy. This will prevent jamming in the Fuser Unit.
              5. Run 50 sky shots.
              6. Check Simulation 25-01 and note the TCD_K value when it stabilizes.
              7. Repeat steps 2 through 6 until the stabilized TCD_K value of Simulation 25-01 is 40 or higher.
              8. Execute Simulation 7-1 and verify that [DV Check Disable] is not highlighted.
              9. Hit CA and make sure machine comes to a ready state.
              10. Turn Machine off/on. Make sure it comes to a ready state.
              11. Make a copy and check the copy quality.
              12. Run Copy Quality adjustment 12a according to the service manual if necessary.
              Note:
              TCD_K value of 26 or less will cause the MFP to display F2-40 error code. Remember that
              the TCD_K Value is inversely proportional to the Toner Concentration. If the TCD_K Value
              is stabilized at 40 or higher, then the F2-40 error code will not appear. Once you recover
              from the F2-40 Error Code, the MFP’s Process Control will take over and regulate the
