Scan to USB problem
  • redserv
    • May 2010
    • 307
    Scan to USB problem
    hello guys, i recently went to a customer that has a MXM453N, when i try to scan to my usb flash drive, and also a couple of others in PDF format, i cannot view the file on the usb drive in document filing, if i use the same usb flash drive in windows i see the files on the usb flash on my desktop, however the customer told me that if they try to scan to usb flash using TIFF format it works. i am totally confused, maybe one off you guys can help me, i also formated the usb drive in windows xp Fat32.
  • OMD-227
    The machine needs Postscript installed to be able to view & print PDF files from a USB drive. You can scan onto the USB drive as a PDF, but if the machine doesn't have PS installed as an option, you will only see JPG, PCL & TIFF files on the drive.
    This is standard specification on any MX or MXM machine.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      I assume it has the PS kit installed ?
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • redserv
        • May 2010
        • 307
        hmm, how could i know if postscript is installed?
        • RRodgers
          • Jun 2009
          • 1947
          Don't the Konica' color boxes support PS out of the box?
          • tmaged
            • Oct 2008
            • 1887
            Check 22-10 or print out 22-6. You could also go to the product key screen, If the PS kit is highlighted, it's installed.
            Hope that helps !
            -Tony
            www.dtios.com
            • redserv
              • May 2010
              • 307
              think i just need to get a product key to enable ps3, am i right?
              • OMD-227
                As Tony has said, check 22-06 print out, or 22-10 machine configuration display to see if PS is enabled. It will be called MXPKX1. If its not listed, then thats the option you need to get installed.
                Its just the PS kit you need to activate via the product key. Once activated, you can load the PS drivers as well as the PCL drivers.
                • redserv
                  • May 2010
                  • 307
                  thanks again guys appreciate all the help
                  • bilyahn
                    • Dec 2006
                    • 1470
                    You are also able to print .prn files from your USB drive. These are word documents that you print to a file. Had to do this as a work around one time until they got their network going properly. Just some FYI if you ever need it!!
                    Good luck.
                    Bil
