sharp ar-m 450n
  • tlc1234
    • Jul 2010
    • 14
    [Error Code] sharp ar-m 450n
    error code L6-10 what is it and how do you fix
  • gwaddle
    • May 2009
    • 782
    Polygon motor lock. I think you can replace the motor, but I'd replace the laser unit.
    I know I should be ashamed of myself. Strangely though, I am not.
    • bilyahn
      • Dec 2006
      • 1470
      Clear the error with sim 14, that may or may not get it working again. What kind of noise it it making? High pitched whine? The laser unit is pretty easy to get to unless you have the finisher or mailbox on the right hand side of the copier.
      Good luck.
      Bil
      • Bluezman
        • Mar 2009
        • 33
        error code
        that L6-10 is a polygon motor lock (LSU) you could try simm 14 to clear it but most likly you will need a new LSU
        BM
        • Scijohn23
          • Sep 2009
          • 91
          L6-10 is the LSU, most likely will have to change it. If you are swapping with another machine or a parts machine make sure it is a 450 LSU. The LSU's in my experince do not interchange between diffrent models.
          • jpcopy
            • Apr 2006
            • 256
            we now replace the motor about a 1/3 price of complete LSU
            • abbas
              • 39
              repalce polygon motor
              • Dark Helmet
                • May 2009
                • 843
                Replace the motor, way cheaper. Just did one last week. The old style motors seem to fail after 3-4 years. Never have had to replace a new style motor.
