AR-336 intermittent power
+ More Options
Posts
  • axyun
    • Aug 2007
    • 1323
    Machine will work for weeks then no power. When I went there I turned on machine and power came on so I didn't do anything. Customer called this morning saying machine did not power up.Frank
  • ZOOTECH
    Senior member of CRS
    • 3375
    Check the solder connections on the dc power supply. The Cougars had a problem with the power transistors attached to the heat sinks.
    • OMD-227
      Yep, gotta agree with Zootech yet again.
      A dry solder joint will do this. Take out the power supply units and carefully check everything.
      • axyun
        • Aug 2007
        • 1323
        Thanks Guys. I must have did something wrong when I started thread as I didn't receive emails. Just decided to check in. Frank
        • OMD-227
          Dont worry about it.... no-one's emails are working.
          You need to check in often.
            • 22997
            Before you pull the power supply, make sure that you're getting 120 VAC to the power supply. A blown surge suppressor could be a very simple cause.
            It's extremely common on Cougars to get cold solder joints on the DC power supply.
            Where I was working, the other techs asked me to do the soldering. On these occasions, I'd give the other tech a 15 minute lead time. By the time I arrived the power supply was sitting on table waiting for the re-touch. Nine times out of ten, re-touching the cold solder joints on the power supply resurrected the machine.
            Re-solder any cold solder joints at IC753, D751, D754, Q754, D771, & ears on the copper heat sink panels. Or replace DC power supply (CPWBF1386FC31).
            Another rare possibility is a temporary 5V short in the SPF. Power can be restored by unplugging the SPF or the red LED can be restored by unplugging CN704 (pin 30: 5V to SPF) on the DC power supply. Reseated connectors on SPF controller. While attempting to track down the short SPF function returned (my guess is the white belt drive motor). This never came back. =^..^=
