ARM 620n farmware needed
    • 23010
    #16
    That, and all the toilets swirling clockwise ...
    • OMD-227
      #17
      Ouch.
      Yep, its 12.30pm monday here. Off to grab some lunch.
      Down under.... the best side of the world!
      • bonnie750
        • 302
        #18
        You take lunch!!!!!!!!!!!!??????????????
        What kind of outfit do you work for mate?????
        Our call controllers take lunch, but there's always one to take over and throw another 2 hour response call behind you.
        Bill
        • OMD-227
          #19
          Lunch is eaten in the car, while travelling to the next call. I have a unique skill of turning corners with my knees .
          • Majed
            #20
            ARP19 Kit What is it ???
            thanks guys for your helping
            those are some pix to make sure about the ARP19 ( is it or not )
            some friends have the same copier ARM620u they are the same in every thing but when we print the customize setting the main firmware for theirs ( Vn 4.04 )
            and the copier I have its main firmware is ( Vu 4.04 ) their copiers work as "N" but main works as "U"
            Why
            I think because of the "Main" firmware
            I don't really know what's the ARP19 Kit exactly
            I'm sure I have the ARP19 Kit but i think I need the firmware for "N"
            I hope If any one can bring me the pix for the ARP19 Kit.
            Thanks All ..
            • ZOOTECH
              Senior member of CRS
              • 3378
              #21
              Main and Boot ROMs will have p4.06 on the chips if it is an upgraded 'U' model; sorry, don't have pictures.
              • OMD-227
                #22
                Are those pictures of you machine? You are clearly missing everything that is needed.
                You see the removeable plate near the Parallel port connector. That gets removed and the network card in the ARP19 kit is installled there.
                If those pictures are from your machine, you do not have the ARP19 kit fitted. Also, simply check sim 22-10 for the machine configuration list. It will tell you all the options fitted to the machine.
                • Majed
                  #23
                  Thanks ZOOTECH and wazza
                  But what about those Pictures
                  Guys , Do think if I take a main flash rom with firmware ( n4. 04 ) and put it instead the one with ( u4. 04 ) firmware in ARM620u. ( it will work or not ??? )
                  • ZOOTECH
                    • 3378
                    #24
                    It will not work unless you put in the P19 option kit. It needs the hardware and a product key to unlock the print option.
                    • OMD-227
                      #25
                      Bingo!
