AR-407
  • T911
    • Jun 2007
    • 628
    AR-407
    circling stars only in the morning hours. things i've done. this one is on a novell system and when you disconnect the machine off the network it will work as a stand alone copier fine.
    1-nic card fixed for a while
    2-icu pcb fixed for a while
    3-ic22 and reprogramed fixed for a while
    4-reformatted hd fixed for a while
    called in for the 5th time in 3 weeks.
    what the ---k with this machine. help much appreciated with this one. thanks t
    • 23008
    I'm seeing stars too...
    The circling stars usually means a bad hard drive, but disconnecting from the network would certainly do nothing to improve your hard drive. Are you sure that it functions fine as a stand alone copier with the network line disconnected? Does it print OK when it does power up?
    You may have two distinct problems:
    1) Bad hard drive for circling stars/won't boot up.
    2) Bad AR-PB2A Print card (and good luck finding one).
    • pjdbm
      • Sep 2007
      • 360
      I have a brand new nic card for this,also have the pb2a print board used
        • 23008
        I'm still seeing stars....
        I'm still leaning towards the hard drive. I have had a few of these go intermittent, and a reformat will get you a few days (but only a few days).
